My apologies in advance if I'm missing something obvious but I noticed the stock to leave in the first operation in each setup is 0.1mm and in the second operation the stock to leave is 0.181mm, is this intentional?
Also, I did simulation with stock visibility turned on for each setup and the rest machining seems to be correct to me.
I think some screenshots of where you are seeing the issue would be helpful for people here to better understand what you are trying to do.
