06-26-2018
09:51 AM
- Mute
- Permalink
- Report
06-26-2018
09:51 AM
@Anonymous
Probably a simple contour will be the easiest and best way to make your slot, see the attached file for a quick example of a contour that is 13.175mm from the existing shape so that`s your 10mm plus the radius of your cutter, I think ![]()
Anyway, try it out and if it isn`t exactly what you want then it can easily be changed, right now it is a single depth of cut but can be set to do steps down if one full depth cut is too much for the machine ![]()
Regards
Rob
Fusion
