- Mute
- Permalink
- Report
Hallo zusammen
Ich habe ein Bauteil das bearbeiten muss.
Hab das meiste auch hingekriegt, nur berechnet mir fusion 360 meine Aussenkontur nicht bis ganz zum Ende.
Das ist ärgerlich da ich so sehr viel schleifen muss.
Ich möchte das der Fräser bis auf die Fläche fährt nach oben. (siehe Bild)
Weis jemand wie ich das programmieren muss?
Herzlichen Dank für eure Hilfe.
- Mute
- Permalink
- Report
Google translate didn't do a good job on your text but try the settings below.
Tool outside boundary.
Mark
Mark Hughes
Owner, Hughes Tooling
- Mute
- Permalink
- Report
Hi Mark Hughes
thanks for our answer.
i try in english.
this setting i have.
i have also tested whit "Machining boundary" silhouette, choice and virtuell frame.
and is it always the same problem.
you have a other idear?
thanks
- Mute
- Permalink
- Report
Are you able to share your f3d design? A couple of thoughts looking at your settings. Rest machining might not be a good idea for a finishing op or you need more clearance, Silhouette + 1mm or more.
Mark Hughes
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
One the file menu there's an option to Export, just save as an f3d and attach to this thread.
Mark
Mark Hughes
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Your biggest problem was Contact Point Bounds selected instead of Contact Only. I added another surface to stop the tool path machining in the pocket. As it's only selected in this op under Model it is not seen by the other ops.
Mark Hughes
- Mute
- Permalink
- Report
ok thanks
i dont say, the model are in a hole in my ground of the cnc.
i dont mill on the ground but now i think its good.
thank you very much for the help.
i test it now and when is ok, i close this question.
i hop my englisch is not sooooo bad ![]()
- Mute
- Permalink
- Report
now i have mill it and it is very very well.
thank you so much.
next week i try the other part.
have a nice week
Fusion
