06-19-2018
09:19 AM
- Mute
- Permalink
- Report
06-19-2018
09:19 AM
Yes, I should have mentioned that. Wasteboard was flycut, totally flat. I can nest and cut with Thermwood's software with no issues. I can nest and cut with Fusion CAM specifying a -.004 cut through ( That's the same cut through we use with Thermwood's Control Nesting), also with no issues, until adding tabs. If I toolpath separately, ie. create a 2D contour with tabs, specify -.004 cut through, and create and additional 2D Contour with the same cut through for the remaining pieces that do not require tabs, I also have no issue. The problem seems to arise when trying to create only one toolpath, part of it with tabs, part without.
Fusion
