06-06-2018
02:47 AM
- Mute
- Permalink
- Report
06-06-2018
02:47 AM
I made sure i used the correct postprocessor for my post and it worked, even with my added modifications.
The code looks now like this:
% O1001 (test) (T5 D=16. CR=0. - ZMIN=-26. - SCHAFTFRSER) (T41 D=45. CR=0. TAPER=45DEG - ZMIN=-1. - FASENFRSER) (T87 D=8.5 CR=0. TAPER=118DEG - ZMIN=-26. - BOHRER) N10 G90 G94 G17 G49 G40 G80 N15 G21 N20 G28 G91 Z0. N25 G90 (PLANEN1) N30 T41 M06 N35 T5 N40 S1060 M03 N45 G54 N50 M51 N55 G00 X174.1 Y-41.572 N60 G43 Z15. H41 N65 G00 Z5. N70 G01 Z3.5 F500. N75 G18 G03 X169.6 Z-1. I-4.5 N80 G01 X152. N85 X0. F750. N90 G17 G02 Y-15.573 J13. N95 G01 X152. N100 G18 G02 X156.5 Z3.5 K4.5 F500. N105 G00 Z15. N110 G17 N115 M09 N120 M05 N125 G28 G91 Z0. N130 G90 N135 G49 (2D-KONTUR1) N140 M01 N145 T5 M06 N150 T87 N155 S1500 M03 N160 G54 N165 M08 N170 G00 X150.841 Y-63.8 N175 G43 Z15. H05 N180 G00 Z5. N185 G01 Z1. F45. N190 Z-24.4 N195 G19 G03 Y-62.2 Z-26. J1.6 N200 G01 Y-60.6 F360. N205 G17 G03 X149.241 Y-59. I-1.6 N210 G01 X1. N215 G02 X-7. Y-51. J8. N220 G01 Y-1. N225 G02 X1. Y7. I8. N230 G01 X151. N235 G02 X159. Y-1. J-8. N240 G01 Y-51. N245 G02 X151. Y-59. I-8. N250 G01 X149.241 N255 G03 X147.641 Y-60.6 J-1.6 N260 G01 Y-62.2 N265 G19 G02 Y-63.8 Z-24.4 K1.6 N270 G00 Z15. N275 G17 N280 M05 N285 G28 G91 Z0. N290 G90 N295 G49 (BOHREN1) N300 M09 N305 M01 N310 T87 M06 N315 T41 N320 S700 M03 N325 G54 N330 M08 N335 G00 X30.761 Y-26. N340 G43 Z15. H87 N345 G00 Z5. N350 G98 G81 X30.761 Y-26. Z-26. R4. F105. N355 X121.288 N360 G80 N365 Z15. N370 M09 N375 G28 G91 Z0. N380 G90 N385 G49 N390 G28 G91 X0. Y0. N395 G90 N400 M100 A2. N405 M30 %
I have modified the older post that i have a "M09" before Z0 so the coolant is off before the tool change is happening.
How do i correctly modify the postprocessor to be able to let it do that?
Fusion
