Stöcker
499 Views, 5 Replies
Coolant M08 not repeating after tool change
i got a problem with a fanuc post i am using.
The coolant information is not repeating after a tool change IF the coolant type is the same as in the previous operation.
O1001 (test)
(T5 D=16. CR=0. - ZMIN=-26. - SCHAFTFRSER)
(T41 D=45. CR=0. TAPER=45DEG - ZMIN=-1. - FASENFRSER)
(T87 D=8.5 CR=0. TAPER=118DEG - ZMIN=-26. - BOHRER)
N10 G90 G94 G17 G49 G40 G80
N15 G21
N20 M09
N25 G28 G91 Z0.
N30 G90
(PLANEN1)
N35 T41 M06
N40 T5
N45 S1060 M03
N50 G54
N55 M51
N65 G00 X174.1 Y-41.572
N70 G43 Z15. H41
N75 G00 Z5.
N80 G01 Z3.5 F500.
N85 G18 G03 X169.6 Z-1. I-4.5
N90 G01 X152.
N95 X0. F750.
N100 G17 G02 Y-15.573 J13.
N105 G01 X152.
N110 G18 G02 X156.5 Z3.5 K4.5 F500.
N115 G00 Z15.
N120 G17
N125 M05
N130 M09
N135 G28 G91 Z0.
N140 G90
N145 G49
(2D-KONTUR1)
N150 M01
N155 T5 M06
N160 T87
N165 S1500 M03
N170 G54
N175 M08
N185 G00 X150.841 Y-63.8
N190 G43 Z15. H05
N195 G00 Z5.
N200 G01 Z1. F45.
N205 Z-24.4
N210 G19 G03 Y-62.2 Z-26. J1.6
N215 G01 Y-60.6 F360.
N220 G17 G03 X149.241 Y-59. I-1.6
N225 G01 X1.
N230 G02 X-7. Y-51. J8.
N235 G01 Y-1.
N240 G02 X1. Y7. I8.
N245 G01 X151.
N250 G02 X159. Y-1. J-8.
N255 G01 Y-51.
N260 G02 X151. Y-59. I-8.
N265 G01 X149.241
N270 G03 X147.641 Y-60.6 J-1.6
N275 G01 Y-62.2
N280 G19 G02 Y-63.8 Z-24.4 K1.6
N285 G00 Z15.
N290 G17
N295 M05
N300 M09
N305 G28 G91 Z0.
N310 G90
N315 G49
(BOHREN1)
N320 M01
N325 T87 M06
N330 T41
N335 S700 M03
N340 G54
N350 G00 X30.761 Y-26.
N355 G43 Z15. H87
N365 G00 Z5.
N370 G98 G81 X30.761 Y-26. Z-26. R4. F105.
N375 X121.288
N380 G80
N385 Z15.
N395 M09
N400 G28 G91 Z0.
N405 G49
N410 M100 A2.
N415 M30
I would need an "M08" after Line "N340".
I have studied the postprocessor for a while but i couldnt find the part in the code.
Thanks in advance for your help!
