- Mute
- Permalink
- Report
hi folks. any way to keep the tool on the surface ? tool 89 contour parralell, third operatrion.
- Mute
- Permalink
- Report
Do you mind changing the strategy. Morphed spiral does a nice job.
Mark
Mark Hughes
Owner, Hughes Tooling
- Mute
- Permalink
- Report
You beat me to it Mark.
I was just making a video suggesting the same thing.
Mike Mattera
Fusion Content Experience Designer - CAM
Getting Started In Fusion CAM | Introduction To 2D Machining | Interface Fundamentals | Keyboard Shortcuts
- Mute
- Permalink
- Report
A little How-To video.
https://autode.sk/2HiBx2J
Mike Mattera
- Mute
- Permalink
- Report
Not at all...im always open for better strategy. i tried it. worked great. thank you. is there any reason this is not possible using paralell?
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
You can force it to stay down. But forcing it on the wrong pattern will probably damage the part. Parallel is just not the right path, because of the shape of the area you're cutting. The reason it retracted was to avoid damage to the surface.
Hope that helps,
Mike Mattera
- Mute
- Permalink
- Report
I guess if they optimised it for jobs like this it could be better but probably not worth the time as it would only help in this situation.
Mark
Mark Hughes
Fusion
