baribak
in reply to: matthew_goulart
Hi Matt,
Can you elaborate on why you need to run the command line install?
Can you send me your installer log file? On windows this is in \users\<username>\appdata\local\autodesk or on the mac it's in /users/<username>/library/application support/autodesk/logs.
Also, if you'd like I am more than happy to give you a ring and assist in getting you up sooner. If this is better for you please send your contact info and aday/time I can ring you to kevin dot baribault at autodesk.com.
Kevin Baribault
Fusion 360 Quality Assurance
