05-24-2018
10:54 AM
- Mute
- Permalink
- Report
05-24-2018
10:54 AM
I'm trying to do a simple 2D Contour to ramp into a slot. The contour defaults to a chamfer tool instead of an end mill for some reason. When I have a chamfer tool selected it generates the toolpath correctly. When I select a 1/4" endmill the tool path fails. My 2D contour is all screwed up. Is there a way to reset to built in default for everything?
With the chamfer tool, if the chamfer box under Passes is checked, the toolpath calculates properly. I think this is a glitch. This only recently became an issue.
This is for Op 2
Fusion
