LibertyMachine
Well, I got good news and bad news.
Good news: It's not you, and it' not something simple you are missing.
Bad news: I don't get frustrated with CAM problems. This file changed that. I've not much clue as to why it's going what it is. The best I can reason out is that there are spots were it simply won't perform a lead-in/out. I've tried multiple combinations of settings and no luck. I can only try to send it up the chain and see if I can get some feedback from Autodesk
@jeff.pek @cj.abraham @angelo.juras  if one of you have a moment (haha) could you take a look at this file? I thought it was being caused by the "Both Ways" and then perhaps it was the stepover, or the tolerance (which is yuuge) or the lead-in/out being too large, but nothing I've changed seems to have an entire effect on the rapid collisions. I've reduced them somewhat, but they still persist.
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
