04-20-2018
12:16 PM
- Mute
- Permalink
- Report
04-20-2018
12:16 PM
I was able to reproduce the problem in a test file. Same CAM settings IIRC, stock height is the same, and the contours of the model represent some of the challenges I'm facing in this model, including undercuts which will need to be machined from the other side. I haven't added any of the work holding bits to this model since they are irrelevant for these purposes and they don't seem to be causing me any grief in the actual model.
The stock and WCS setups are pretty much identical except in length and width of the stock. Also you'll note that I'm not including the setup model in the Adaptive Clearing, but picking the model again just to be sure it has the correct geometry. Hopefully this gives you more to go on.
Fusion
