- Mute
- Permalink
- Report
HELP!!! on cutting a skateboard.
I made a wood mold and compressed with the layers of sheets and trying to cut it to size. Only I can think of is using 2d- trace but the problem is the edges that have 45 degrees(red arrow) to be cut.
What's the best option to use in Fusion 360?
Thanks !
- Mute
- Permalink
- Report
Scallop would be my first try
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
- Mute
- Permalink
- Report
Seth,
Thank you for the prompt response.
I did a quick try on Scallop feature but this is what I am getting. what setting should I change to make this work?
- Mute
- Permalink
- Report
It's set to Silhouette for your Machining Boundary. Set it to "Selection" and select the areas you want to cut. If you share your file, I can knock out a quick demo video for you
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
- Mute
- Permalink
- Report
That'll be awesome.
Please see the attachment.
Thanks a lot!
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Seth,
I really appreciated the video, There are other areas that I need to practice on.
Thank you again.
Fusion
