marcoCAGYK
217 Views, 3 Replies
Shaft and holder pull away cut the lead-in radius
when I select pull away or trimming in the shaft and holder menu the tool goes with the correct distance from the model, but in that point it cut the lead-in radius, only in that point, and the tool enter in plunge in the model and creates a bad surface finish. There is a way to maintain the lead-in when the tool go away from the model?
Marco
