marcoCAGYK
217 Views, 3 Replies
Shaft and holder pull away cut the lead-in radius
when I select pull away or trimming in the shaft and holder menu the tool goes with the correct distance from the model, but in that point it cut the lead-in radius, only in that point, and the tool enter in plunge in the model and creates a bad surface finish. There is a way to maintain the lead-in when the tool go away from the model?
Marco
marcoCAGYK
in reply to: marcoCAGYK
Sorry I forgot to write that happen when I use the 3D contour strategy
jodom4
Hey marcoCAGYK,
Please share your model here- you'll be much more likely to get better help faster.
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
marcoCAGYK
in reply to: jodom4
I'm trying to do the 3D contour of the model attached, whit a tool body lenght 50mm.
