rsreed
in reply to: hoptownhandles
I know this is a post from last year, but could you share the Post Processor you are currently using on your IQ HHC w/4th axis?
I just added a 4th axis to my Laguna IQ, and the PP from Laguna (for Vectric Aspire, V-Carve) is works correctly, as it just substitutes the "X" values with "A" when wrapping geometry.
However, I tried the PP that you shared at the start of this thread and I keep getting "X" values in the NC. Everything else appears correct but shouldn't the X-axis stay at the origin? And should it even be showing in the NC unless a G0 X0.0 Y0.0 Z20.0 line is needed to go to the origin at the start of the job?
