It is the 2D contour where the problem was useing the 3D contour seems to be good I have given you 2 different contours one that has crashies one that does not have a crash.
If you look at the settings I used you will see why it does not touch the problem area, you will need to use a different toolpath in the area.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
