It's because it's a 2D contour you are useing, 2D toolpaths are dumb toolpaths they are not model a wear so they do what you make them do where a 3D toolpath will know whats around it and you just point it to where it is to cut.
Using a 3D contour seems to work quite well, it's getting some crash warnings because of material still there I will see if I can clean it up a bit more then post the model back.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
