martin.dunschen
Hi @Anonymous
There could be a hung process: My suggestion is to check windows task manager (assuming you're using Fusion on Windows, if it is on a Mac, use the equivalent process manager) and find processes called camkernel-x64.exe, and kill these manually. Best is to quit Fusion first, so that you can be sure that these are hung processes.
It would be great to be able to recreate the problem as @AmandaFowler suggested, but I appreciate that you can't share the design, but if you can recreate the problem in a different design and can share that, please let us know.
Martin
