dudu_268
1938 Views, 3 Replies
Chamfer inside a hole Impossible to do it Intelligently
Hello
I'm trying to do a 45º chamfer inside a hole with a chamfer mill.
The hole smaller diameter is 6.1mm and the bigger 12mm and of course there is already a Pre-Drill.
Does anybody can do it with this tool?
I attached images with tool and hole dimensions.
Tags (1)
porsbym
in reply to: dudu_268
Try a 2D Contour with the upper edge of the chamfer selected for the geometry. It compensates for the tip of the tool by default, but you can adjust that using heights or axial stock to leave.
2D Contour also has additional chamfer options available on the passes tab when using a chamfer tool. You don't need those in this case, though.
/Mark
dudu_268
in reply to: porsbym
Thank you man!
It worked and I didn't have to use the stock to leave feature.
porsbym
You are quite welcome. Glad to hear that it worked!
