- Mute
- Permalink
- Report
I am having issues as well. I have a valid part that we have been using in class and I had generated toolpaths for an aluminum test piece. I made some minor adjustments to the model and had everything going well. This is a two sided piece and the bottom is going to be machined first then a relief on the top in order to mount it in a fixture for the third and final setup. I had an Adaptive toolpath, then a circular one with a final 2D finishing pass on selected geometry. This was fine and the simulations went well until I tried to adjust settings on the final pass.
I ended up deleting that operation as it seemed to begin when it was generated. That seems to not be the case. Now when I open the project ANY process I click on immediately gives me an "Invalid Toolpath" error and the only options you can get are by using a right click but those options are limited to CONTOUR SELECTION, PREDRILL PASS AND ENTRY POSITION. You can expand the process tree or collapse the process tree but the only way to get the error to close is to go to any other view ie Sculpt, Model, Patch Mesh etc and then back to the CAM but the error returns as soon as you try to edit a toolpath.
Attached is a video link to show.
Fusion
