Hi Neal,
The more I think through this, the more I think I am doing something wrong in my tool library setup.
This AM I went out to the machine and changed the tool offset by 1 inch lower and the z axis responded starting the program 1 inch lower than before.
This is the same post as I was using with Vectric, that Autodesk first modified to remove the M17 and M16 commands that were causing me problems....but then I had to add in my coolant commands manually. Then you took the post and added the coolant commands.
So for all practical purposes this is the same post that I have been using successfully all along with Vectric.....the one thing that has changed is I am using Fusion instead of Vectric.....I just bet a nickel I am setting something up wrong in my tool library.
Let me know if you have any suggestions on what I may be doing incorrectly.
