02-02-2018
06:10 AM
- Mute
- Permalink
- Report
02-02-2018
06:10 AM
It doesn't expect anything, as the speeds and feeds will need to be calculated for your cut parameters and tooling.
As an example I use a 1/2" four flute variable helix end mill up to 1.5*Ø, 10% radial cut at 8000 RPM and 168 IPM in mild steels, and that's fairly conservative. Feedrates can go as high as 240 IPM with no ill effects, and that is a general purpose AlTiN coated end mill.
If you want a good calculator for HSM toolpaths I highly recommend HSMAdvisor: https://hsmadvisor.com/
Very satisfied customer is all, I have no relation to the company.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Find me on:
Fusion
