Steinwerks
The 2D toolpaths aren't stock-aware so they won't see the remaining stock. The Rest Machining setting there is in order to clean out corners or geometry left by a larger diameter tool.
You can sort of get 3D Contour to work, but It's less than ideal. You might be better off making a few independent 2D Contour operations and alter the Tangential Extension distance into large negative values to trim just the tabs away individually.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
