- Mute
- Permalink
- Report
I confess, I don't know why the ordering is so terrible.
Maybe @jeff.pek can direct this towards the developers, and in the meantime I suggest making a Selection Set usage in the Ideastation here: https://forums.autodesk.com/t5/hsm-ideas/idb-p/231
If location changes are a concern, you can always use Bore Mill in the Drill cycle. Ordering for that isn't stellar either (Gibbscam in my experience always had the best traveling salesman solution), but it will save you tons of programming and calculation time. I've attached the file with that strategy in it as a comparison, but didn't really spend much time tweaking the heights so there is room for improvement on that front.
You could also do a Bore Mill cycle on one hole and then pattern it so all diameters are done at each location.
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Fusion
