in reply to: Steinwerks
it appears i'd have to supply the pattern dimensions and directions (effectively duplicating the pattern). it doesn't seem to function the same as "sketch driven pattern" or a feature driven pattern such as is found in an assembly model that drives number and arrangement of parts based upon the seed item's features.
in other words, if i went back and changed the hole spacing on the original pattern, i'd have to also make the same change on the hsm pattern. at first glance, it also appears that the CAM portion of fusion 360 does not have access to the part parameters (under the idea of creating a parametric pattern, and supplying that info to the hsm pattern).
perhaps i missed something?
