techshopjim
666 Views, 4 Replies
How Do I Get Fusion to Make "M06 T8" Instead of "T8 M06" for Fanuc?
Hi Everyone!
I'm doing some CNC projects at Jamie Hyneman's shop in San Francisco (where Mythbusters was filmed).  He has a Fanuc control on a Sharp SV-2412 milling center that you may have seen on the show.  I'm using the machine to make stuff for him and for me.  It is a very nice machine, and works well with Fusion 360.
However, we are having one problem.  When I output gcode with the generic Fanuc post in Fusion 360, I get something like this:
O1001
(T8 D=0.25 CR=0. - ZMIN=-0.31 - FLAT END MILL)
G90 G94 G17 G49 G40 G80
G20
G28 G91 Z0.
G90
(FACE1)
T8 M06
S8000 M03
G54
M08
(I added the red bold as emphasis of that line.)
We couldn't figure out why the Fanuc control would start to run the gcode file and do the zeroing just fine, but then stop at the tool change line "T8 M06".  After looking at Fanuc forums, we discovered and verified that the like "T8 M06" needs to be reversed to "M06 T8", then it works fine.  Some Fanucs can use either command order, but some Fanucs cannot.  Ours apparently cannot.
How can I get Fusion 360 to produce the corrected gcode?  Do I need to make a change to the Fanuc generic post "fanuc.cps" or is there another way to make Fusion 360 reverse the commands in that line?  I'd rather not have to edit gcode every time I make parts, especially if there are a lot of tool changes throughout the gcode file.
Thank you!
