infoVGDMP
in reply to: LibertyMachine
Hi Seth
Thanks for the reply but still does not work. I have Fusion 360 Basic so perhaps this is the problem? I have tried 2d Contour,Face........all with an Endmill, and it still does not let me select just the upper/lower edge on the Y-Axis. Instead it selects the entire lower/upper perimeter. Am at a bit of a loss here and thought this would be a basic function of Fusion 360 as this is required as one of the fundamental processes for squaring off stock! I have my vice mounted on the Haas table as shown in the picture below (please ignore facemill) and want to use the side of an end-mill to run along the Y-Axis (highlighted in green in accordance with stock point origin) to square off the stock. I can select the other 4 faces in Fusion but it won't let me select the left and right faces running along the Y-Axis??????!!!!!! Any advice would be greatly appreciated.
Many thanks
Alistair
