utekcnc
652 Views, 5 Replies
Another Turning Question--File Attached
I'm trying to get the hang of turning in Fusion.  Quite different from Gibbscam it is.    I have attached a file.
1.  Tooling--Is there anyway I can enter in my Sandvik tool number and have the right tool?
2.  My partoff tool......It has a 5 degree relief on it.   Where can I enter this?  I can't seem to see that when I create the tool
3.  I normally program the partoff in Gibbs like this:  I do a groove peck just deeper than the chamfer.   Then I profile along the chamfer and down the back of the part to part it off.   What is the most efficient way in Fusion to cut the chamfer on the back OD of the part.
4.  What parameter or setting do I need to change for the boring bar return point to be higher in X.  I can change it in the Gcode, but would like to get it right here.
Thanks!!
