in reply to: jeff.pek
Having put more thought into this and reading on this forum I am considering using a 'template' for the 2D profiling. My main objective is to eliminate the need for repeatedly inputting feeds, speeds, tools, passes etc each time we lay down a profile (placing the parts is easy so I am happy to let my trainee do this - but having to repeat the 'programming' is likely to introduce costly errors) to be cut. If he could simply place profiles into a sheet as and when needed, apply a template for the profiling and hole boring (that is all we do really) then that would be great.
However having saved a 2d profile template, if I try to use this in a new file as soon as I load the template by right clicking on setup - create from template I am presented with 'no valid toopath' and 'unable to process selected operations'. It does not matter how many times I hit OK these messages just repeatedly pop up anytime I go near the browser with the cursor, so I am prevented from being able to edit the operation, setup etc.
Below is hopefully a shared model....
http://a360.co/2kqZdsP
