AmandaFowler
in reply to: kmcgheeCMFPG
Hi @kmcgheeCMFPG,
Thanks for posting - when I program something like this where I want to predrill a hole, I do a drill operation for the holes and then use the "entry position" option inside of the contour path to select where the tool will start.
Let me know if that helps you out!
Amanda Fowler
Technical Support Specialist (CAM / HSMWorks)
