Thanks! I will do some testing with this.
The interesting part is this post was edited by Andrew and Wayne with Autodesk after I provided them with a post from Vectric which I was using for my CAM application. The one in Vectric was close but added M17 and M16 commands that caused issues with the controller and I was needing to edit them out.
I run several tests and let you know if this works.
Thanks again for the assistance!
