fonsecr
in reply to: atrueresistance
I suspect the extra time might be due to overhead in the serial transfer time (you are drip feeding). If your CNC supports uploading the entire NC program directly before starting it you can try this and see what the machining time is without the IO. In your picture you only show 2D pocket operations so I dont think that the extra time is due to the CNC not being able to keep up with the programmed feeds as long as they are relalistic.
René Fonseca
Software Architect
