jeff.walters
HSM is designed to use 1 (your input offset) as the first offset for your machine. This way you can changer between machines easier. Now when you enter 54 what happens is the system then assumes you want to use the extended work offsets, hence the G154 output. This behavior is controlled by your post.
Jeff Walters
Senior Support Engineer, CAM
