Seth - comparing gcode that worked and code that didn't, same opening code lines, then stepping it thru, I discovered what I believe my issue was that after the initial tool change it raises the tool to Z=0, and during the rapid to the first cut, vibrations were setting the Z limit switch off.  I've never had problems with my limit switches before, so didn't suspect them.  the code that ran had a short rapid move before first cut, the problematic one traversed the whole 48" table.  well, I'm learning about gcodes.  didn't really want to.
