3490 Views, 7 Replies
G154
Set work offset to G54, setup sheet says G54. NC code has G154. Using Haas post. Any idea what setting is responsible for this?
HughesTooling
It looks like the post is setup so you just enter your offset from 1 to 24. If you set it to 1 the post outputs G54 and so on.
Mark
Mark Hughes
Owner, Hughes Tooling
Perfect! Thank you Mark.
jeff.walters
HSM is designed to use 1 (your input offset) as the first offset for your machine. This way you can changer between machines easier. Now when you enter 54 what happens is the system then assumes you want to use the extended work offsets, hence the G154 output. This behavior is controlled by your post.
Jeff Walters
Senior Support Engineer, CAM
in reply to: jeff.walters
Makes sense, and thanks for the extra detail.
matthew
Fusion 360 users,
The WCS offset works like this...
Numbers 0-6 output g54-g59, the default being 0, they are as follows
0=g54
1=g54
2=g55
3=g56
4=g57
5=g58
6=g59
Numbers 7 and up will output a "g154 P#" (Haas users) or "g54.1 p1" (Fanuc, Mazac ...).  This means, for Haas users, if you wanted to output the offset "g154 p1" you would input "7"
The input 54 would give you an output WCS "g154 p48"   (54 - 6 = 48)
-Matt
See image below for WCS Offset box.
Steinwerks
in reply to: matthew
This has been covered many times, but I do have to point out that you've dug up a thread from nearly two years ago Smiley Wink
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
matthew
in reply to: Steinwerks
Thought a good explanation this function was in order!
