523Industries
@Anonymous wrote:
One thing is for certain, my machine can't handle the speeds and feeds generated by fusion. I also want to say I tried a couple other CAD / CAM solutions and so far I'm really impressed with fusion. Keep up the amazing work!
The speeds and feeds are fully adjustable, what your machine might be having problems with is the amount of code generated by an operation and being able to process is appropriately.
This can also be adjusted to a point with changes to the Tolerance, using Smoothing, adjusting the Lead-In and Lead-Out, etc.  If you expand an operation you'll see the size of the code that'll be generated, and you can see what changes to the parameters (and others) do to the size of that code.
Nick Santiago
