- Mute
- Permalink
- Report
Thanks for posting! It's good to get such a detailed explanation of your problem. Please could you share the code that you used for this bore operation? Have you checked that the active work origin is correct? Your work origin may have been switched to the machine default so it can return to its home position, then never switched back to the origin you have set.
The next thing to check is seeing if your machine is losing steps.. Some machines have a check when homing the axes (return to limit sensors) to show you the difference in position from the previous time the axes were homed, this would tell you if the machine is gradually losing steps whilst cutting. I would guess it's not this, as you would probably see the effect inside the bore operation.
Hope this helps
George Roberts
Manufacturing Product managerIf you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
Fusion
