ovisopa
in reply to: vladimirtrubin
I'm no guru, but I opened you file and I'm not sure if that is the area you are trying to pocket, is that it ?
I noticed that both 2D adaptive and 2D pocket are failing in creating a good toolpath (it mills through the model) but the 2D Contour operation seems to make an usable toolpath, if you need to mill quick a part, and can't wait for an answer from the guru's around here, maybe you can make a pocket with a STOCK TO LEAVE value to avoid milling through the material, and than make an 2D CONTOUR operation to finish the internal edge
Good luck!
