Lonnie.Cady
262 Views, 1 Reply
Fusion turning very slow using Spun profile
Any one seeing any significant speed issues when using turning spun profile?
I have a model that is not too complex but requires a spun profile to get any useable geometry for turning.  All of the dialog boxes seem to respond very slow.  Even just tabbing thru the dialog is very slow.  They are just slow enough to make you wonder if you actually double clicked to edit the operation.  When I switch to the model environment I don't see the same issues.  Also I don't see them in operations for a milling set up on the same part.
jeff.walters
in reply to: Lonnie.Cady
Lonnie i have been out a couple of days have you sent this file in? i ask becouse i havent seen any issues on my (simple) parts.
Jeff Walters
Senior Support Engineer, CAM
