- Mute
- Permalink
- Report
I am milling a pocket that is a lot like a slot. In the past I have been able to adjust the tool offset diameter at the machine to increase the width of the pocket. This particular post when I change the diameter offset on the machine nothing changes. I even made the error of not pre setting the offset to the diameter of the end mill being used. Normally that would have resulted in an oversize or undersize pocket.
What am I missing?
- Mute
- Permalink
- Report
Thanks for posting. Are you able to share the model you are using? I would assume this is an issue with the compensation type that is selected
Cheers
George Roberts
Manufacturing Product managerIf you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
- Mute
- Permalink
- Report
Thank you, yes I can share the model but I don't know how. Please explain.
- Mute
- Permalink
- Report
thanks for the reply. The easiest way is to export the file as a Fusion 360 archive file. To do this, choose the export option from the Fusion file menu as shown below:
Once the export is complete, simply add it as an attachment to your reply ![]()
Cheers
George Roberts
- Mute
- Permalink
- Report
Thank you for the help. The mention of the compensation type was enough and I figured it out.
Fusion
