Cary.Brace
in reply to: Steinwerks
Ok, like I said, thank you. That helps a lot. However if you watch the video link I put in you will see that the cut is in multiple passes and there is a point  when his tool exits it does a move to max height before it returns for the next path. With the trace tool I am limited to one pass. Do you suggest that I make the trace path and put it in a canned cycle so that my tool returns home and then moves in .1" or so and repeat until the desired depth? Do you have another solution. Please watch the video I would like to use the Y axis for my Z depth the way it is in the video if possible. Let me know what you think. Thanks
