jeff.pek
in reply to: shaneU6DLB
If you're using just a single part, then that's true.
To get what you want, you should create a separate model, and then insert the original part (as an X-Ref) into it.
This way, if you update the part model, then the "assembly" will retain any CAM operations.
Jeff
