2352 Views, 4 Replies
Disable Canned Cycles
New user.  Is there a way to disable canned cycle output for post processing?  Some older machines don't use canned cycles, ie G83.  In MasterCam you can output the gcode as long hand for threading, peck drilling, etc.
jeff.walters
that can be done in the post for you. If you go to the Autodesk CAM forum post section and ask there one of hte post team will be happy to get you cutting.
https://camforum.autodesk.com/index.php?board=3.0
Jeff Walters
Senior Support Engineer, CAM
If you're comfortable editing you own post, just look for the function:
   function onCyclePoint(x, y, z)
Make sure that:
   expandCyclePoint(x, y, z);
   return;
is the first thing that happens and it will expand the cycle to the appropriate moves.  I had to do this for my lathe post.
Dave
chu.jacky
that works great. thank you!
Z-K-O
Works for me too. Great tip.
