dbeetcher
in reply to: LibertyMachine
Hi Seth,
Thanks for your quick response!
I tried doing what you suggested, but all that seems to do is to rotate the stock 45 degrees, but it doesn't rotate the fretboard too. I did a test drawing with a simple fretboard shape (rectangle). Then drew a plane at a 45 degree angle. I switched over to CAM mode and, in Setup, selected Z and X axis, clicked on the top of the part for Z axis, then clicked on new plane for X axis. All it did was to rotate the stock, but not the part itself (see attached JPG). Any suggestions?
Thanks, Dan
