09-17-2017
08:05 AM
- Mute
- Permalink
- Report
09-17-2017
08:05 AM
You can draw and model your part anyway you prefer. If you find that you need to "rotate" the part in the CAM environment, all you need to do is create a plane at an angle and use that when you define your setup:
Create Setup
Select Z and X axis
Select the top of the part (or router bed) for your Z axis
Select this new plane to represent the X axis
All set!
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Fusion
