08-18-2017
09:12 AM
- Mute
- Permalink
- Report
08-18-2017
09:12 AM
What is your pattern material? Wood, butter board, aluminum?
The first foundry pattern I made the foundryman laughed at how polished it was. Most short run patterns are wood. Sanded and painted is usually good enough. One time I had a pattern maker convert one of my patterns to urethane for better durability... he covered the whole pattern in tape, made a plaster mold, and cast the urethane from that. Looks every bit as good as the original.
I normally do my drafts using tapered end mills so I can finish the walls in one or two passes.
In your case contain your wall finishing and use a separate operation to finish the flat with a larger step over. Something like this.
Fusion
