Matthew-R
@Anonymous Thanks for submitting your question to the forum.  If you've followed the article that you linked, your posts should be showing up for you.  I created a quick Screencast hopefully explaining a bit more about post locations.  Also, make sure that the file extension was maintained as a .cps because if it has changed, it would not show up in the list.  Thanks again and let me know if this issue is still persisting.
Here's another important link you're most likely aware of, our post processor library where you'll find that Stepcraft CNC post.
Autodesk Post Processor Library
Screencast
