The license provided with the PocketNC is only for one year, and will need to be renewed at the end of the year.
In order to do 3+2 Axis Fusion 360 Ultimate is required: https://www.autodesk.com/store/products/fusion-360-ultimate?term=1year&support=advanced
Fusion 360 Standard supports full 3 Axis machining, but does not include features like 3+2 positioning and 5 Axis toolpaths. (Ultimate also has other features).
In my demos I  am cutting Machinable Wax, and I am using a 2 flute 1/8th endmill, running at 9,000rpm, cutting at 40 in/min, .125" to .25" depth of cut.
Best,
-Xander Luciano
Xander Luciano
CAM Content Developer
If my post is helpful, press the Kudo button - If it resolves your issue, press Accept as Solution!
Quick Tips: When to resselect CAM geometry | Understanding Smoothing in CAM | Adaptive Facing | Online GCode Viewer
