randyT9V9C
in reply to: OliverDownie
I went ahead and imported your 3d drawing. I built a few quick paths to give you an idea. You can do this in three operations.
Setup 1: Pocket out the three 1.5" hole. Extend the pocket into your waste board. Install your dowel pins. If you use hollow pins you can then hold your material down through the pins.
Setup 2: 3d contour front side.
Setup 3: 3d contour the back side.
See the attached file for reference. You'll need to adjust the tools and such to your liking. :winking_face:
Here are some pics that may help.
