07-04-2017
04:09 PM
- Mute
- Permalink
- Report
07-04-2017
04:09 PM
That post is out of date you will need to use the new tormach post found here http://cam.autodesk.com/posts/
If you have your 4th axis sitting on the right side of your machine pointing to your left you use X or -X if it's on the right pointing at you you use Y or -Y.
The bit circled in the pick is what is needed to be set, not Yes if you have no need to output 4th axis code you set it to none.
What the arrow is pointing to needs to be X or -X for the 4th axis on the X axis, Y or -Y for the 4th axis on the Y axis and Z or -Z if it's pointing at the Z axis
Is the 4th axis on your machine like this pick
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Fusion
